Yeah you can posted by -Grimm- on December 06, 2013 at 09:00 AM
unplugged. you'll fill the cylinders with fuel unless if you've pulled the green fuel pump fuse by the battery. Your symptoms sound indicative of a incorrectly installed timing belt or a cas that is misbehaving. but the compression results lead me to believe the timing belt was set incorrectly.
